Has anyone with 25mm spacers had the camber checked out? Is there too much negative camber, because.
Old Apr 30, 2003 | 06:18 AM
CooliceTTT's Avatar
New Member
Default Has anyone with 25mm spacers had the camber checked out? Is there too much negative camber, because.
it sure looks that way.
Old Apr 30, 2003 | 06:38 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Probably.......>>
Lowered an inch with 25's came out at -2.5 on my car....
Old Apr 30, 2003 | 06:43 AM
Pearly's Avatar
Junior Member
What are the effects of negative camber? Is it dangerous?
Old Apr 30, 2003 | 06:44 AM
seaTTym's Avatar
Member
Default Just adding spacers won't affect camber...the camber will look more severe because
the wheels are now pushed out farther and are more visible.
If you;ve lowered the car, then that is another story.
Old Apr 30, 2003 | 06:55 AM
CooliceTTT's Avatar
New Member
It is not dangerous per se, except it will wear tires unevenly
Old Apr 30, 2003 | 06:56 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Not optimum....>
To have excessive negative camber. Handling and tire wear are affected.....aim for -1.5 to -1.7 as a good setting
Old Apr 30, 2003 | 06:59 AM
Pearly's Avatar
Junior Member
Thanks
Old Apr 30, 2003 | 07:02 AM
ooyahhh's Avatar
Junior Member
Default Re: Speaking of alignment has anyone tried adding some front toe out?
Thinking it would reduce understeer and have better turn in.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 30, 2003 | 07:19 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default It will make the car a little twitchy....>>
and directional stability will be compromised a bit...Good for a temporary AutoX situation but not day to day. Do other things...
marksk1
May 8, 2007 02:43 PM
snowpunk_AGTT
Feb 5, 2007 07:44 PM
mrpeugeot
Audi Original "S" Cars
Jun 9, 2006 04:45 PM
TTington
24
Dec 2, 2004 07:12 AM
TTeleven
38
Jan 24, 2002 06:48 AM
