Some chips a waste of money?...
I have talked to a number of folks with 225 hp TTs here in CA and the general consensus seems to be that there is very little performance difference versus stock.
I've driven in chipped 180s, and the chip seems to make a substantial difference. However, in CA at least, the chips don't seem to do much for 225s.
Anyone want to confirm or deny this?
Now that I have my car set up better (working) I am very happy and can for sure say that even with the 91 octane, a chipped 225 is more powerful than a stock 225.
I have the APR chip on my A4 for 3 years and never had a problem.
If I only had 91 octane available I would not chip a 225.
This combination gives you added hp, but also the much-needed added torque.
You will definitely notice a difference on the 225 with this combo.
Late last fall I got the 93 oct upgrade, as we do have abundance of 93 oct gas here.
This gave a good amount of added performance across the RPM range.
A definite improvement, but you need the base program to build on also.
One other thing: the Samco intake hose.
This is a must, I'm convinced.
I had been noticing boost bleed-off in the upper RPM ranges with the APR, and the 93 program.
I installed the Samco intake hose last weekend, and got an immediate lift and sustained boost in the upper RPM ranges in all gears.
Do the chip, exhaust, and the Samco, and you will definitely notice a difference.
