BV problem
Old May 2, 2003 | 12:22 AM
Verra's Avatar
New Member
Default BV problem
Anyone of u have a weird sound when the car is underpower shifting(like shifting up to 3rd from 2nd in 1200rpm)?
Old May 2, 2003 | 04:48 AM
Kreggin's Avatar
Default Re: BV problem
Search on DV - if it is sort of a honking then you likely have the dreaded, but easily fixed, crappy Bosch DV problem. The hard part will be sorting out all the opinions on which DV to replace it with. I have the Forge DV's on both my TT's and have had not trouble since they were installed.
Old May 2, 2003 | 08:27 AM
Verra's Avatar
New Member
did u get them install at the dealer? the dealer said if i installed a new DV ....the warrenty will be voided =(, that's lame....
Cheers,
Verra
Old May 2, 2003 | 11:19 AM
Kreggin's Avatar
I know all about that ! I've been having trouble with sencond gear synchro for over a year. I show up for the repair with the Forge DV and they tell me that it has boosted the horsepower and caused the failure. I pointed out that it was in for service with this problem before the DV failed, and I replaced it. No joy - butt heads all the way. You can install yourself, get the black one - it doesn't stand out. If need be you swap the dog back for your trips to the dealer.
sofTTware
22
Sep 6, 2004 07:46 AM
RoberTT-WWCD
Jul 15, 2002 06:38 AM
Les' Red TTR
Apr 6, 2001 01:28 AM
quicksilverTT
Nov 16, 2000 08:46 AM
BlueS4orce
Oct 26, 2000 02:56 AM
