I just vagged block 217 for air fuel and was wondering what
Old May 2, 2003 | 02:05 PM
Lightweight-USPowah's Avatar
Default I just vagged block 217 for air fuel and was wondering what
numbers are considered too rich or too lean.. The lowest I saw on my 20min drive was about 10.3:1 which happened to be a 4th gear run.. During around town driving the numbers stayed around 14.7...
Old May 2, 2003 | 07:05 PM
RoninTT's Avatar
Default I think it's common practice for chips to run extremely rich in the higher RPM's to keep the EGTs
down. If you saw 10:1 at 6k RPM, that's probably the chip doing its thing. I read somewhere that 12.something:1 ratio gives maximum power so I don't think your far off. If you saw that at idle, or anything below 3k RPMs, I'd worry.
Old May 2, 2003 | 11:23 PM
carfanattic's Avatar
New Member
Default Re: I just vagged block 217 for air fuel and was wondering what
You have to do a WOT run to check your A/F ratio. My O2 V goes down to 0,6V which is 8,82:1 to keep the EGT at 920°C. I'am getting 17,5PSI boost at 6500rpm.
BlackS4tt (Josh)
Oct 9, 2005 08:23 PM
fouroheight68
Sep 11, 2005 08:09 PM
Mat Indukts Lambos
Performance and Tuning
9
Mar 28, 2004 05:45 PM
neonhero
Apr 10, 2003 08:12 PM
Kirath ¾-B0§t0n
Nov 9, 2002 05:39 PM
