2nd gear problem...
Old May 2, 2003 | 02:23 PM
Verra's Avatar
New Member
Default 2nd gear problem...
I tried to push the shifter against the left wall of the gear box in 2nd gear...no luck ....still kinda hard to shift in....btw i found that, downshifting from 3 to 2 is smooth ..
1 to 2 always lame.....except in extremely low rpm in 1st gear and up shift to 2nd....dealer finds no problems.....Damn...
Cheers,
225TTQ owner 2001
Old May 2, 2003 | 02:45 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Re adjust the cables....>>
Hit the Dieselgeek site for instructions...
Old May 2, 2003 | 02:58 PM
FinnTT's Avatar
Default same problems...
1 to 2 is lame, except sometimes it's very smooth. Two repair shops have not found the problem.
Done so far:
- Cable adjust + greasing
- Transmission oil change
Let me know if you find the root cause. My prime suspect is currently faulty clutch main cylinder...
Old May 2, 2003 | 04:00 PM
Verra's Avatar
New Member
its only for TT that has short shifter?!
Old May 2, 2003 | 04:15 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default No...The cable alignment is the same...>>
go here. Follow these instructions for a perfect alignment...<ul><li><a href="http://www.dieselgeek.com/ATTQoriginstall.htm">http://www.dieselgeek.com/ATTQoriginstall.htm</a</li></ul>
roro
9
Aug 20, 2020 11:48 AM
DaveO121872
Mar 5, 2014 04:44 AM
Verra
May 1, 2003 08:39 PM
rootkid
9
Mar 26, 2003 01:09 PM
doctorno
Mar 28, 2001 10:34 AM
