x-chip problems... caught on Vag
While vagging the BOV I decided to check up on ignition timing while doing a highway run.. As I was getting on the highway in 4th gear, I went wide open throttle, and after shifting into 5th at 5800rpms boost dropped to 10psi.. The green line is engine speed plotted against time, light blue is ignition timing, while yellow, pink, dark blue, and purple are ignition timing retardation.. Im thinking about installing a boost controller BUT before I do that I need to find out exactly why boost is dropping.. If its because I was spiking too high then fine, BUT I I don't think that is the cause of me loosing boost.. Tonight Im going to do a few vag runs one with boost vs ignition timing, and I will also check up on the knock sensors.. : / Hopefully something good will come out of these vag runs..
<img src="http://images2.fotki.com/v23/photos/3/30429/200574/IgnitionTimingHighway-or.jpg">
