Still installing AWE boost guage, how do you get silicone hose
Old Jan 31, 2004 | 04:51 AM
graviTTy's Avatar
New Member
Default Still installing AWE boost guage, how do you get silicone hose
through wiring connector box. Inst. indicate there is a white box under R side of cowling, mine"s, black and is a complete cover with 10mm fastners, removed fastners but wiring is integrated thru black plastic cover. there appear to plugs R & L of center wiring harness, can u drill thru one of those and rubber gasket or grommet with hose thru there?
Old Jan 31, 2004 | 05:25 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default There is a hole through the firewall..>>
Just above the throttle petal. Most of us use that one. Pull the rubber plug and fish through..It'll come out to the left and below the brake master cylinder. No need to drill additional holes..
Old Jan 31, 2004 | 05:35 AM
JustJeff's Avatar
Default looky, clicky
<img src="http://jbipes.home.comcast.net/jpgs/boost4a.jpg"><ul><li><a href="http://jbipes.home.comcast.net/ttr/boostgauge.html">Boost Gauge Hose Routing in the TT</a></li></ul>
Josh/AWE
Audi A3 / S3 / RS 3
Dec 11, 2008 10:47 PM
SparTTan
Apr 30, 2005 03:57 PM
GoTToGo
Jan 27, 2005 07:52 AM
fourwheelslide
13
Nov 9, 2004 09:19 PM
Cyan S4
Aug 1, 2001 08:31 PM
