Revo Chipped Problems
Old Feb 2, 2004 | 11:42 AM
texauditt's Avatar
Member
Default Revo Chipped Problems
Has anyone had problem with the Revo SPS3 install causing the rpm to increase (to 4000 rpm) and drop back (to 3500 rpm) at high speed (80 mph,)when accelarating hard, then gradually increase normally? Also shifting is not as smooth as when in stock mode and getting a honking noise when accelarating. Have changed to Forge DV and back, noise is not as noticeable with stock DV. Unable to reproduce problem in stock mode for dealer repair. No codes are being shown.
Old Feb 2, 2004 | 11:51 AM
madfish's Avatar
Junior Member
revo'd for a year and no probs so far
Old Feb 2, 2004 | 11:58 AM
dannyTTnyc's Avatar
Senior Member
Default no probs,
what settigns are you running?
have you tried lower settings?
do you have a vag?
i noticed that the car was smoother after revo on the lower settings, and as you get more agressive with the settings, the drivability goes down a bit.
Old Feb 2, 2004 | 12:08 PM
texauditt's Avatar
Member
Default Re: no probs,
Low Boost Mode Dial "A" set to 3 and Range Dial "B" set to 9 with Timing Mode Dial "A" set to 5 and Range Dial "B" set to 6. Have been revo'd about two weeks and problems has been persistant since install.
Old Feb 2, 2004 | 12:16 PM
Angel B7's Avatar
Default timing seems a little agressive..
I run High boost 1(4-1), timing 5(5-5) and it is perfect. The stock Revo program is the equivalent to low-boost 9, timing 4..
ClearlakeTT's Avatar
New Member
Default No problems except...
..watching for the Police.
Old Feb 2, 2004 | 12:23 PM
texauditt's Avatar
Member
Default Re: timing seems a little agressive..
I'm running 93 octane with temperature in the mid 50's or lower with timing and boost set at the settings. Will try your suggestion when I pick it up from the dealer this evening.
Old Feb 2, 2004 | 12:43 PM
texauditt's Avatar
Member
Default Re: No problems except...
Who did your install, I went to San Antonio and had it done.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 2, 2004 | 12:54 PM
dannyTTnyc's Avatar
Senior Member
Default timing shouldnt be a problem...
but ive found 4-1 to 4-3 timing 5 to be the sweetspot on my car for nice driving.
i usually fill up with 94 octane
Old Feb 3, 2004 | 03:52 AM
New Member
Me too, had a trip up there and fitted DV at same time. A different car after that.
zion
Apr 1, 2006 07:08 AM
Phat_Bastage
Aug 25, 2005 01:14 PM
zhenya
17
May 16, 2005 10:29 AM
PSmalls::DoggieStyle
10
Sep 20, 2004 07:53 PM
QGMika
Performance and Tuning
9
Mar 19, 2003 01:34 PM
