Can someone please explain to me what the boost machine is, and can it be installed...
Old Mar 26, 2004 | 10:31 AM
SlickBlackS4's Avatar
Default Can someone please explain to me what the boost machine is, and can it be installed...
on my 225 tt, my only mod is my forge 007p. TIA
Old Mar 26, 2004 | 10:36 AM
the Quiet sTTorm...'s Avatar
Member
Default Re: Can someone please explain to me what the boost machine is, and can it be installed...
<ul><li><a href="http://public.fotki.com/ttschwing/boost_machine_and/">GO HERE!!!</a></li></ul>
Old Mar 26, 2004 | 10:51 AM
EasTTcoasTT's Avatar
Senior Member
Chipped cars only afaik.
Old Mar 26, 2004 | 10:57 AM
HACK THS's Avatar
Default NOT true, I use it in stock mod on my check- boost around 14psi...
under chipped mode though I get around 21-22psi. You know this though ;-)... it still does work in stock mode, problem is that you will never get the full potential out of it, cause around 15psi you get a max pressure fault in the engine and goes into limp- same way when I was boosting to 25psi while tuning the machine.
Old Mar 26, 2004 | 12:34 PM
AxeYrCat's Avatar
Member
*cough hack*! BOOST MACHINE FAQ IN MY SIG!
dbarbau
1.8T Discussion
Dec 30, 2010 11:01 AM
Im@wesome~ out!
Feb 21, 2007 11:12 AM
Straz85
Feb 26, 2006 06:47 PM
Pearly
May 8, 2003 10:04 AM
s4drvr2000
11
Jul 26, 2002 03:46 PM
