Another Mod Test ... What does this measure ?
I spent more on the Fuel Hose than the extra Filter!
1) reroute (no cutting) the supply side Fuel line over the top of the Radiator reservour
2) add your Edelbrock (hot rod) filter to keep your injectors Extra clean
3) add your (optional) Fuel Pressure Guage
4) Route your output back under the Turbo Pipe
and you have Fuel Again !
- Idle: 38 PSI (2.6 bar)
- slightest throttle: moves quickly up to ~ 45 PSI (3.1 bar)
- "zero boost" moderate throttle moves to ~ 52/54 PSI
- Pretty Full Boost 17/18 PSI (1.2 Bar) delivers 62 PSI of Full Presure (4.3 Bar)
- Peak Boost of 20 PSI (1.4 Bar) gives a quick trip to 65 PSI!
Most Entertaining
