Help me choose what to do with my suspension!
Old Jun 14, 2004 | 10:15 PM
r6ashih's Avatar
New Member
Default Help me choose what to do with my suspension!
okay I have Bilstein shocks, eibach springs and 1/2 kmac camber kit installed on the upper bars
my camber is within spec, but my toe is not.
Should I
A.) swap out the upper bars with the lower bars (is this safe?) + alignment
B.) Buy other half of kmac ($130), pay for install(50+?)+ alignment
C.) Buy forge/stratmosphere Tie bars ($345) + alignment
are there any differences between forge and strat tiebars?
thanks
Old Jun 14, 2004 | 11:58 PM
Russ Scott's Avatar
Default "A" will fix it....
Forge bars use harder bushings for "performance".. Strat uses the factory bushings to retain OE compliance...
Old Jun 15, 2004 | 07:13 AM
dt23's Avatar
New Member
Default Re: "A" will fix it....
what's "oe"?
Old Jun 15, 2004 | 07:25 AM
r6ashih's Avatar
New Member
original equipment
Old Jun 15, 2004 | 07:44 AM
Russ Scott's Avatar
Default Sorry! OE = Origional Equipment
I shoulda said "stock ride"
More on camber correction: with the KMAC or bars installed in the "lower" position, adjustment will correct excessive negative camber AND excessive toe-in at the same time. In the upper position: adjustment will improve camber, but the toe-in stays the same, or gets worse. The camber correction device should always be installed, first, in the lower position. Rarely, some cars require more correction and a second setup needs to be installed in the upper arms. But always start with the lowers. This will handle all but the rare case.
kclee1st
Oct 28, 2015 10:25 PM
353/s/
Aug 15, 2006 04:16 PM
S4iscool
9
Oct 30, 2002 07:35 AM
aviatorgray
Jan 31, 2002 07:21 PM
