Is this normal for alignment specs...
Old Aug 15, 2006 | 10:40 AM
353/s/'s Avatar
Default Is this normal for alignment specs...
First off these guys (Morgan Mechanical) that did my alignment are awesome and have done other cars for me.
They told me that LH rear axle partial toe is off by +0.43 degrees with a target of 0.13 degrees. The RH side came out to +0.11 degrees (within spec).
I have the ECS adjustable tiebars and now I'm wondering if I should do the K-macs?
Any feedback would be great. TIA
Old Aug 15, 2006 | 10:51 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default If they've already used up all the slot adjustment....>
On the trailing arm, then you'll need an upper Kmac to get any more..
<img src="http://images14.fotki.com/v219/photos/7/7305/63346/trailingarm-vi.jpg">
Old Aug 15, 2006 | 11:58 AM
kodeTT's Avatar
Elder Member
Default yup. you'll need it to adjust the toe when its relatively low...i have uppers with Kmacs and
lower Forge tie rod. can pretty much adjust for anything. have new KW 8012 springs going in...so we'll see how that goes.
Old Aug 15, 2006 | 01:02 PM
353/s/'s Avatar
So a half k-mac kit should be fine... right???
Old Aug 15, 2006 | 01:14 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Yup....1/2 up top.>>>
In combo with the lower bars oughta do it..
Old Aug 15, 2006 | 04:05 PM
MOBlueTT's Avatar
Member
Unless you're lucky like me and had to do both to get w/in spec, er um well -1.6 ish :-P
Old Aug 15, 2006 | 04:16 PM
353/s/'s Avatar
Cool... Thanks Steve!
Linc's S4
Audi Original "S" Cars
16
Jun 25, 2008 03:09 PM
[KRAFTIG]
Canadian Discussion
Aug 9, 2006 05:37 AM
Phil White
Motorsport Discussion
Aug 23, 2002 01:33 PM
aviatorgray
Jan 31, 2002 07:21 PM
