If I don't go coilovers, what's the best way to go? Pics? I had Bilstein/Eibach on my A4
Old Jun 15, 2004 | 06:57 AM
GreekTTCharlie's Avatar
Default If I don't go coilovers, what's the best way to go? Pics? I had Bilstein/Eibach on my A4
and it was a decent setup
...I'm just not sure of how much I want to spend on suspension.
I want to get it down about 1.5 to 2 inches.
Any pics of some non-coilover suspension setups showing ride height? TIA.
Old Jun 15, 2004 | 06:58 AM
CusTTom
Elder Member
Go same route.
Old Jun 15, 2004 | 08:20 AM
Russ Scott's Avatar
Default Ditto /\ /\
The Bilstein/Eibach combo is widely used and well liked on the TT..
The 1.5-2.0 inch drop you would like is not provided with this combo however. You'll get more like 1.0 inch. The TT has about 3.5 inches of compression travel available. You can only give up so much of this to lowering before constant bottoming ruins both ride and handling. The shorter shock absorber/strut body and shaft used with most coilovers has the effect of increasing compression travel. This permits drops greater than the 1.0-1.25 available with most spring/shock setups. The Bilstein sport has a shortened shaft (but not "body") and this helps some. But to get 1.5 to 2.0, coilovers are pretty much your only choice.
Old Jun 15, 2004 | 10:29 AM
Would I need camber plates for a 1 to 1.25" drop?
Old Jun 15, 2004 | 11:10 AM
CusTTom
Elder Member
You might need a 1/2 a kmac in rear
QS -
11
Dec 8, 2004 06:54 PM
gliTTch
11
Mar 11, 2004 12:25 PM
2000.5a4
Dec 10, 2003 06:02 AM
AGreen
9
Nov 29, 2002 06:40 AM
seaTTym
Performance and Tuning
Oct 5, 2001 08:21 AM
