Broke Dipstick Holder - Some days nothing goes right.
Old Nov 7, 2004 | 09:46 AM
coasTTal's Avatar
Default Broke Dipstick Holder - Some days nothing goes right.
As part of installing the Dahlback manifold I was wiggling the yellow tube that holds the oil dipstick and then SNAP, it comes off in my hand.
The yellow tube is part # 06A 103 663 B.
It snapped just above the metal tube going into the engine.
What a pisser.
Any suggestions?
Old Nov 7, 2004 | 09:58 AM
JustJeff's Avatar
got JB-weld?
Old Nov 7, 2004 | 10:07 AM
coasTTal's Avatar
Default The tube wall is about 1/16"+, do you think it would hold in that high temp and vibration?
Would Auto Zone, Murray's carry this?
Old Nov 7, 2004 | 10:09 AM
JustJeff's Avatar
It'll hold 'till you get a new part from the dealer. :-) no auto-parts store will carry this, soory.
Old Nov 7, 2004 | 04:54 PM
OldSchool AG's Avatar
Senior Member
Duct tape
Old Nov 8, 2004 | 03:48 AM
ModifiedA4's Avatar
Banned
Default get a new part and replace it...
<ul><li><a href="http://www.modifieda4.com/web/tech/dipstick-tube.html">i wrote an article on how to replace this part on an A4, should be similar for the TT</a></li></ul>
Old Nov 8, 2004 | 10:36 AM
coasTTal's Avatar
Default Thanks, and questions.......
Mine is already broken almost down to the flaired point. I will be picking up a new tube this afternoon.
Am I to presume that the yellow tube has an inner and outer section that slips over the metal tube below?
I was going to try 2 different methods to remove what is left. I don't like the breaking off method for fear that stuff will drop down the tube.
Method 1:
Get a section of 1/4" threaded rod and put a nut on one end up and inch or two from the end. Drop as small washer on top of the nut, then add a second nut on top of the washer. I would then insert into the tube and try pulling upward to release the remaining part of the tube. Obviously I can't pull on 360 degrees of the area.
Method 2:
Put a stop collar around the tube and tighten to a very loose fit, but enough to fit underneath the flared portion of the yellow tube and then pull upward.
Any idea how much force it takes to get this thing to release?
Old Nov 9, 2004 | 06:31 AM
ModifiedA4's Avatar
Banned
Default yes, it seats on the OD and ID of the metal tube...
the breaking off method is fine if you go slow.
<img src="http://www.modifieda4.com/images/dipstick-tube/DSC00117.sized.jpg">
as you can see, I broke off small pieces from the inside out with a pliers. because the plastic is so brittle, only what is gripped by the pliers breaks away(for the most part).
No large chunks dropped down the tube. I nibbled the plastic tube down slowly and when i got to the end i pried the last piece off and picked the small ring left behind.
Also, keep in mind...it is plastic and any pieces that drop are going into the oil pan....i.e. before the filter.
I did the nibble method because i wanted a controlled disassembly of the tube, i didnt want to try to yank it off in one piece and have it explode...
hope this helps...like i said...the risk isnt that high because:
a: its plastic
b: pieces will drop before the oil filter
good luck
 Pouria Savadkouei
 Michael S. Palmer
bondi
A4 (B8 Platform) Discussion
9
Aug 25, 2014 12:48 PM
eTTie
9
Dec 3, 2007 08:49 PM
eTTie
Florida Discussion
Jun 12, 2006 07:30 AM
