VAG-COM QUESTION
Old Dec 3, 2005 | 06:01 AM
BierBurner's Avatar
Default VAG-COM QUESTION
Does anyone know how to set the service intervals to 5k instead of 10k.
Old Dec 3, 2005 | 06:08 AM
MarTT's Avatar
Default I just turn them off using this procedure:
To reset the Service Reminders using VAG-COM:
Select Control Module 17 - Instruments, then Adaptation - 10, Channel 02 - set to 0 to reset.
Old Dec 3, 2005 | 06:29 AM
BierBurner's Avatar
Do you know if it is possible to set it at 5k
Old Dec 3, 2005 | 07:22 AM
furiousgeorge's Avatar
Pretty sure it is, but I ran out of time before i got done playing around. I haven't got back to it.
Old Dec 3, 2005 | 08:44 AM
BierBurner's Avatar
Default I guess I will just have to play around.
Of course making sure to write down original numbers.
Old Dec 3, 2005 | 10:23 AM
DasTT's Avatar
Default Depends on instrument cluster rev...
Not possible on my '02 after it is initialized. It is possible on a cluster replacement if you do it as part of the coding for the odometer. You only get one try.
The alogorithm is based on time and distance, so there are two settings. One is days and the other 100's of KM. If you don't drive a lot, the service reminder will come on after one year (default), otherwise the 10K miles.
Old Dec 3, 2005 | 03:42 PM
BierBurner's Avatar
Default That would mean that I would not be able to set to 5K.
I guess I will just reset it and change the oil a 5k left on service interval. Thank for all the help.
Uriah
fonseca_Q5
Q5/SQ5 MKI (8R) Discussion
10
Jun 14, 2011 01:54 PM
Mark Jacobs
Audi allroad
Jan 11, 2009 06:17 PM
MattA4-A3
Audi A3 / S3 / RS 3
Aug 29, 2007 03:05 PM
Tourette(AFC2.812v)
12v V6 Discussion
Nov 6, 2005 07:00 PM
sloth-fratelli
Audi 100 / A6 (C4 Platform)
Jun 30, 2004 06:27 AM
