Questions about the Greddy RS relo mod...................
2. Can the vacuum nipple be rotated by taking off the top of the Greddy and rotated so it comes out a different direction?
3. Finally I know this has been covered but should I remove one of the internal springs, I am not chipped yet but will be eventually.
Thanks
<img src="http://images14.fotki.com/v248/photos/6/645139/2489087/31GreddyatDVRelovicopy-vi.jpg">
to rotate the nipple, unscrew it, followed by the 5 screws holding the assembly together. With the top off you have access to the springs. Some run just the outer spring, with the adjustment screwed in (try a search for the latest on this) others run both springs with the adjustment unchanged. Replace the top carefully, placing the nipple in your preferred orientation. You're good to go!
