help with Fuel trim numbers
Old Dec 5, 2005 | 03:52 PM
Rocky-in-Connecticut's Avatar
Default help with Fuel trim numbers
2001 Audi TT 225 quattro
anyone know if I have a leak?? It's too cold out for me to try and track down a vacuum leak unless I really have to. Vag Com reports block 32 numbers of (1.5, 9.4)...part throttle number looks out of wack but no CEL is thrown (yet). Anything to worry about? I checked boost numbers block 115 and they look good.
If I do have a leak, it may be that L hose under the intake manifold I suspect.
Monday, 05 December 2005, 19:22:04
VAG-COM Version: Release 504.1-UD
Control Module Part Number: 8N0 906 018 K
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 06710
Work Shop Code: WSC 01236
Additional Info: TRUWT28N211024850 AUZ5Z0YN300080
No fault code found.
Old Dec 5, 2005 | 03:57 PM
TTinCT's Avatar
Rest In Peace
Default If that is a positive>>>
9.4, the software is correcting for a lean condition, not rich. Probably a MAF on the way out....IMO
Old Dec 5, 2005 | 04:47 PM
Default forgot to add...
my rear o2 sensor in block 30 was reading 110,
while the front was 111. Is this a problem?
Old Dec 6, 2005 | 05:07 AM
RoberTT-WWCD's Avatar
Default Check block 002 and do a WOT in 3rd...>>
g/sec should be => 170 for a stock 225 (i think). Anyways, anything less than 165 prolly means weak MAF.
Drpheonix
Nov 29, 2009 01:16 PM
rktskicar
Aug 26, 2008 12:37 PM
guido_TT
VAG-COM Discussion
15
Mar 9, 2007 11:11 AM
EricBss7_CT
Aug 3, 2006 05:55 PM
Jaco
Audi A3 / S3 / RS 3
Jan 31, 2006 10:48 PM
