Question for airbag light gurus
The airbag module throws NO CODES whatsoever (I have a ProDiag).
<B>Question:</b> Does the lack of codes mean the airbag controller is Ok? Even an intermittent problem should throw a code, right? So this more likely a cluster issue... or a connector-resistance issue in cold weather?
<B>Bonus Question:</b> It happened 2 yrs ago the first winter I had the car but disappeared when the dealer replaced the brake switch; now it's back. Is the brakelight circuit tied into the Airbag startup diagnostics?
Puzzled in Chgo... where it's COLD,
~john
<i>(PS: sorry about the repost but I'm stumped and the car's out of warranty)</i>
Not sure if that has anything to do with your problem, just thought I'd give you the data point.
Thanks for the data point.
