Question:
Old Feb 11, 2006 | 04:21 PM
Basttion's Avatar
Default Question:
If you assume that wheel spacers are acceptable (within reasonable thicknesses) then would a bolt pattern changing wheel spacer (ie 5x120 --> 5x100) be equally acceptable, given the offsets were within spec?
Thanks all
Old Feb 11, 2006 | 04:57 PM
nikhil's Avatar
Default yup
if you trust spacers that bolt to the hub (e.g. h&r 25mm spacers), there's no reason not to trust adapters.
Old Feb 11, 2006 | 05:19 PM
Basttion's Avatar
Default Thanks man! You're very helpful, as usual. :)
So I guess the trick is to find the spacer and adapter all in one if you're gonna go that way.
Old Feb 11, 2006 | 06:30 PM
nikhil's Avatar
Default no problem
my buddy was telling me about a shop that will make you custom adapters, so if you can't find what you need from the regular places, let me know.
Old Feb 11, 2006 | 07:24 PM
Basttion's Avatar
Default I wonder if this is the same one?
I found some potential wheels, but they're 5x112. We'll see how it goes.<ul><li><a href="http://www.wheeladapter.com/home.asp">wheel adapter</a></li></ul>
1 Mean TT
Sep 15, 2005 11:17 AM
ttuner333
11
Aug 26, 2005 12:47 PM
OldSkewS4
Sep 1, 2003 07:07 PM
TittieTwister
Dec 20, 2002 08:03 AM
