Got CEL, DTC 16795, Secondary Air injection incorrect flow..>>
Old Feb 14, 2006 | 06:17 AM
TTDirk's Avatar
New Member
Default Got CEL, DTC 16795, Secondary Air injection incorrect flow..>>
Had this before, thought perished vacuum pipe fix on combi valve would fix it, nooot! What is the most common thing that goes wrong/fails with this system: Combi valve, solenoid valve or air motor or connections at one of them? Experiences?
I have Bentley instructions but what simple tests should I focus on first? I cannot get underneath the car easily.
Where is the solenod valve located?
Old Feb 14, 2006 | 06:24 AM
TTinCT's Avatar
Rest In Peace
Default Check your DV for leaks. If it is diaphragm based>>>
it could have a slight tear in it. If it is a DVR, insure that the screw cap that covers the spring is pulled down tight....
Old Feb 14, 2006 | 06:40 AM
TTagz's Avatar
Senior Member
Default I think I had that same code...
not positive, but I think so. Dealer replaced secondary air injection pump under warranty. Not sure if that's the only fix. It's just an emissions thing when the engine is cold, I would probably just ignore it or see if I could trick it.
Old Feb 14, 2006 | 07:08 AM
Rocky-in-Connecticut's Avatar
Default put vacuum pump on the combi valve
if your combi valve does not hold vacuum there is your problem.
Old Feb 14, 2006 | 07:32 AM
TTDirk's Avatar
New Member
What if I don't have a vacuum pump, suggestions?
Old Feb 14, 2006 | 07:36 AM
TTDirk's Avatar
New Member
Default BTW the readiness test after driving the 2 Mi to work this moring showed 00101101meaning>>
O2 sensor fail/incomplete (car was not at full running temp yet)
seconday air inj fail,
Catalytic conv fail
Old Feb 14, 2006 | 07:38 AM
TTDirk's Avatar
New Member
Thanks, checked it last week, will take it out entirely, check and re-assemble
Old Feb 14, 2006 | 08:15 AM
TTinCT's Avatar
Rest In Peace
if you were in there last week...i betcha that is your problem...IMO
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 14, 2006 | 01:19 PM
Default not nearly enough driving to reset readiness code
it can take several complete driving cycles to reset readiness code. By one complete driving cycle I mean engine completely warmed up, driving on the highway for dozens of miles.
You could use Vag com to more quickly set readiness code.
Old Feb 14, 2006 | 01:20 PM
buy a $30 one or borrow.,
