Wierd sound when braking ..
Old Feb 14, 2006 | 07:18 AM
L8TE APX's Avatar
Default Wierd sound when braking ..
When I apply firm or hard brakes on my 01 TT there is a knocking sound that comes from the area aboe the break pedals. Sounds like a short pop and it only does it once. Any ideas/
Old Feb 14, 2006 | 08:23 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Could be..>
Worn strut tower bushings. How many miles on the car?
Old Feb 14, 2006 | 08:32 AM
L8TE APX's Avatar
25,000....about 1000 track miles
Old Feb 14, 2006 | 08:38 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Little early for those then, but look at them..>>
The strut tower caps should have about 3/8th of an inch clearance between them and the body of the car. Pop the hood and look. Much more and they're starting to collapse.
Applying brakes torques the strut forward. Look at other things that are known to cause noise like sway bar links, the bar itself, Ball joints, caliper mounting bolts, etc...
Old Feb 14, 2006 | 11:23 AM
bubba j's Avatar
AudiWorld Expert
Default I had the same thing. Started happening after tracking the car.
Took it to a race prep shop and they did a "nut and bolt." Spent 2 hours or so tightening everything on the car to spec. That solved the problem. Have no idea which bolt, obviously.
Replacing the front struts, links, strut bushings, etc did nothing. Also retorqued the subframe bolts. Nothing worked until the "nut and bolt."
Old Feb 14, 2006 | 12:52 PM
L8TE APX's Avatar
Thanks...I will check it out
foxfire256
Jun 29, 2011 05:30 AM
rowdyzombie
May 24, 2008 07:18 PM
dmac
A4 (B7 Platform) Discussion
Nov 17, 2007 01:23 PM
bcart82
Jul 20, 2007 05:04 PM
GDawgA4
Jul 23, 2006 04:51 AM
