Help!!! Seems the rubber door seal has "de-glued" itself from the door...suggestions on the...
The rubber strip is the long strip attached from the bottom of the door to the tip of the small triangular door window(supposed to be tucked underneath the door panel)....the bottom is fine as its attached with plastic clips....however, it seems the rubber along the hings are "glued" on....but now it has unglued itself!
How the hell am I going to reglue without removing the door....any suggestions how and why this happened?
Had the car rust sprayed(I'm paranoid as I live in Canada with lots of salt and want to keep this car rust free as long as possible)before winter and would all the rust application reacted with the glue holding the rubber strip???
Help me
Thanks in advance!
Can't sleep tonight till I hear a suggestion on how I can reattach it
