AC/Fan problem
Thanks,
ByTTeMe
You will see three green fuses. pull them out and inspect.if there is one that is burnt then replace it and see if the fans work.Also inspect the fuse socket and see if it is burnt. If it is then replace the fuse board. It's as easy as eating flapjacks with butter)
