Window Woes
Old Apr 18, 2006 | 09:56 PM
ondafly's Avatar
New Member
Default Window Woes
Hi Folks - having trouble with the drivers windows, and now the central locking. Car is a 1999 Right Hand Drive 180T Quattro Coupe, with 43K on the clock.
some of you may have seen my thread RE: Window not going up etc -
http://www.tt-forum.co.uk/ttforumbbs/viewtopic.php?t=59850&start=0
or a short recap
-Drivers door window would not close
-Took door card off and pulled up a bit
-Took regulator out of door, and untangled Boden cable, although it was so fraid, its useless now. So intead left motor disconnected.
-Started car, shut doors, locked doors. Smoke came from drivers side at window switch relay. Switched off car !
-Opened passenger window too, but then that wouldn't close. Took panel off that side, and manually closed window.
-Reconnected motor on drivers side - smoke stopped
-Got out of car, turned on alarm. and Car went mardi - Lights flashed, doors locked unlocked.
-Disconnected battery for 1 week.
-Eventually reconnected battery, removed fuse for central locking, and drove to Dealers.
We ended up waiting for a appointment with Audi to fix the car. Dropped it to them on 12/4 with full details of what was wrong with it.
We got the car back on the 14/4 for a bill of ^138, nothing fixed, and the windows just wedged shut.
Heres the job info on our receipt.
JOB Details :
Plugged car on would not go into 35-46. Removed Door panels to check if blocked connectors on motors - They were.
Replaced 2 blown fuses. Replaced Fuse 3 - 8 Fuse Blew - Lights flickered first then blew. Fuse 38 is for central locking ECU.
Tried new central locking control unit to see if it is blowing fuses - not control unit nor are the motors blowing fuses. Car requires
D/S/F window regulator for glass 110 euro and 2 hours labour at 79.50 p/hour plus VAT at 13.5%. Central locking Major fault. Would Quote
6 Hours Labour for same. Car needs to be re-booked.
How nice
I also got a copy of the computer read out of the car.
VAS 5051B Version BASE V08.00.00 08/11/2005
Vehicle system:
35 - Central Locked
8N8962267B
Central Locked/alarm D04
Coding 4810
Dealership number 01236
02 Interrogate Fault memory:
13 Fault/notes detected
01366 035
Opened due to crash signal
01374 035
Alarm triggered by terminal 15
01370 035
Alarm triggered by interior monitoring
01558 029
Close contact switch in locking culinder
driver side - F241
short to earth
01616 036
Signal wire for interior monitoring
Open circuit
sporadic
01568 028
Signal for convenience opening
short to positive
sporadic
00956 009
Key 2
Value above upper adaption limit
sporadic
01570 029
Terminal 15 cut-off delay
Short to earth
sporadic
01559 059
Driver Door
does not disengage
sporadic
01559 061
Driver door
deadlock does not disengage
sporadic
01482 029
Central locking motors
short to earth
01134 049
Alarm horn H12
No communication
01134 076
Alarm horn H12
Terminal 30 missing
So now we have the car re-booked for next Monday, but from the looks of it. We are initially looking at ^250 to fix the window regulator, and a possible 480 in labour to work out what is wrong with the central locking of the car, and who knows how much more money to repair it.
Does anyone have any ideas ? Will a refit of the regulator solve the problem completely ?
Old Apr 19, 2006 | 02:27 AM
TTGram's Avatar
Member
And I thought it was bad that my passengers window only worked sometime.
Old Apr 19, 2006 | 03:45 AM
Rocky-in-Connecticut's Avatar
Default window motors been replaced before?
window motors are a known issue and must be replaced in pairs. But it sounds like you have a wiring issue (pinched wiring?) and/or a door lock module issue as well. The tech probably will need more time to diag.
Old Apr 19, 2006 | 02:59 PM
TTest-D3MON's Avatar
Did you try hitting the motor with a hammer? Worked for me...
Recman
Sep 24, 2017 02:42 PM
mmaguire2
Jul 11, 2008 04:18 PM
rotuspeed3
Apr 21, 2006 08:46 AM
Clubscene
Feb 20, 2003 05:27 AM
joffrey
Dec 11, 2001 09:38 PM
