Rotburgers. Pulled the pass side fuel pump today to clean sender...didn't cure problem
Old Apr 23, 2006 | 05:00 PM
fignewton's Avatar
Default Rotburgers. Pulled the pass side fuel pump today to clean sender...didn't cure problem
have the same problem others have reported; gauge goes way past full on fill up, then after 300 miles is only down to between 1/2 and 3/4. Went and picked up a seal Fri, then did it this morning. Kind of a PITA job, but it would be easier now that I know what I'm doing. Writeups and Bentley didn't exactly prepare me for putting it back together-- nothing says that there isn't anything that literally locates the pump in the bottom of the tank. Geting the pump out is a close fit, and of course, all the lines and hoses in the way don't help.
No signs of any corrosion on the contacts at all, but I cleaned them anyway. Not sure if I will get another seal and pull the driver side unit and check it. Talking to Rod at Currys the other afternoon while having my alignment done and tires mounted, he said he's starting to see more failures of the sender itself on the higher mileage/older cars.
Guess I'll have to pull this one back out to disconnect the lines for the driver side one. PITA x 2.... :&gt
Fig
Old Apr 23, 2006 | 05:04 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Did you try the Techron cure?....>
MarTT posted a link the other day to a chevron page. Apparently it's common with lots of cars now......
Old Apr 23, 2006 | 05:22 PM
fignewton's Avatar
4 fill-ups in a row, added a bottle each time. Could by why no sign or anything in the tank.
Old Apr 23, 2006 | 05:30 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Try the other side......Worth a shot..>>
or cough up the bucks!
Old Apr 23, 2006 | 09:08 PM
erikazra's Avatar
New Member
Default Re: Try the other side......Worth a shot..>>
anyone in los angeles fix their fuel sender problem i could pay to do mine?
Old Apr 24, 2006 | 04:55 AM
RoberTT-WWCD's Avatar
I cleaned the Primary (passenger side) sender that fixed my problem.
skl1
Q5/SQ5 MKI (8R) Discussion
10
May 12, 2014 11:30 AM
bennya8
Aug 10, 2009 05:35 AM
emmett03
Audi Original "S" Cars
Feb 15, 2006 06:07 PM
S6 4RiNGS
18
Feb 23, 2005 09:27 AM
Twisted5000
Jun 21, 2003 09:15 PM
