I'll finally be able to join the "lowered audi TT group" LOL!
In addition to that, to adjust the rear you have to put a jack under the hub for support. Pull the bottom shock / sway endlink bolt. Drop the hub a bit (using the jack). Adjust as needed. Jack up the hub to align the bolt. Torque down the bolt.
Put on tires. Drive, smile.
Having the jack there isn't critical, but it is nice to hold things steady while you are trying to put the bolt back in. Plan an hour for adjustment on all four corners, taking your time with a tape measure and a pad to see where you are. The adjustment on the rear is deceptive, as the amount of adjustment translates to a longer throw at the hub. I will reply to this post later tonight with a means to convert between the adjustment and the actual drop (I have one more measurement to do).
--Tim--
