Coil pack update, Dealer replaced the coil pack......
Old Apr 24, 2006 | 08:08 AM
blackfnTTruck's Avatar
Default Coil pack update, Dealer replaced the coil pack......
before I gave approval. charging me $339.00 for oil change and replacing one coil pack. Not covered under warranty because of the component failure code they have to put into the computer. I said I quess you are telling me that someone damaged the coil pack, he said yes, either me or someone who worked on the car. Yes I am getting the coil pack back, since I paid for it. I AM SO PISSED !! And I still have one original in my car yet to fail.
Old Apr 24, 2006 | 08:11 AM
Vodka G's Avatar
Default so you are sayin>>>>
that you car is under warranty and they are not covering the coil pack replacement???
WTF???
i did give AoA a call for that caz the coilpack should def be covered under factory warranty (or CPO warranty)
Old Apr 24, 2006 | 08:14 AM
Basttion's Avatar
He did. Read the post below to catch up... \/ \/ \/ \/ \/ \/ further down\/ \/ \/ \/ \/
Old Apr 24, 2006 | 08:19 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Bastards...I would go back to your first dealer...>
They're the only ones who could have broken the pak...
Old Apr 24, 2006 | 08:20 AM
GeTT da NeTT's Avatar
I'd be hot too. I think you need to elevate your complaint. Service Manager?
correct, 19k miles on the car, second time towed in for coil packs.
Old Apr 24, 2006 | 08:22 AM
Are you saying these things don't usually crack when they fail?
Old Apr 24, 2006 | 08:24 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Dunno....>>
I thought they were failing electrically. No ones ever reported a cracked one here that I recall. I may be wrong though. A ham fisted install could certainly crack one though...
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 24, 2006 | 08:30 AM
TTagz's Avatar
Senior Member
Default If they replaced it before you gave approval, then they can't charge you...
it's the law. you don't have to pay for unauthorized work.
Old Apr 24, 2006 | 08:35 AM
coasTTal's Avatar
Just wondering but how much do coil packs cost?
