Secondary injection - incorrect flow saga (still unsolved) ...
Old Apr 24, 2006 | 11:31 AM
007TT's Avatar
Default Secondary injection - incorrect flow saga (still unsolved) ...
Well, checked for hose integrity, replaced the combi-valve and relay, took out the solenoid and pressure tested it with it on and off, ran the output tests for solenoid and air pump; all are fine. With the output tests, I can hear the solenoid, relay and air pump operate. I'm still getting this annoying 16795 incorrect secondary air flow code.
Can anyone suggest something else that I should try. This issue is driving me nuts as I've trying to resolve for the last 8 months. My mechanic has no clue either.
Thanks in advance,
Henry
Old Apr 24, 2006 | 11:40 AM
Rocky-in-Connecticut's Avatar
Default you must be leaking vacuum somewhere
make sure the vacuum lines to the combi valves are not cracked and leaking.
ModifiedA4's Avatar
Banned
Default the only other possibility is some sort of cat/o2 sensor problem.
it sounds like you checked the integrity of the rest of the system pretty well.
Old Apr 24, 2006 | 12:19 PM
007TT's Avatar
Default I did pressure check the braided line ...
that goes from the solenoid to the combi-valve with a vacuum pump up to 25psi and no leak. Other lines I visually checked. Sigh...
Old Apr 24, 2006 | 12:28 PM
ModifiedA4's Avatar
Banned
was there soot in the pump side of the combi valve?
austindh40
Feb 14, 2017 03:23 PM
Nichole77
12
Apr 4, 2016 01:16 AM
grisoni
9
Feb 22, 2009 02:01 PM
Mortt
Dec 7, 2007 06:39 AM
AuDIY
Audi allroad
May 1, 2006 04:59 PM
