Have I mentioned my coil pack failure? One more question........
If you need to check resistance of the primary coil (through series MOSFET), you may need to connect the gate pin to power (Try a 3V or so battery)
To check the secondary, high voltage winding, you can probably check the output after you pull that connector out, and then one of the wires on the connector. It will probably be the ground one. You should be looking at low ohm values, like a transformer as you stated.
