H&R Springs = Neg. Camber?
He suggested that I go with the koni sport/eibach combo if I wanted to avoid the camber issue.
Anyone found this to be true?
I'd rather go with the H&R springs since they're a little lower than the Eibachs. According to the site it says the H&R springs lower the car 1.3 inches in the front and 1.2 in the rear. However the Eibachs lower the car 1.1 front and rear. Is this accurate and will I even notice the difference?
Lower the car more than an inch and you'll definitely need some additional adjustment range to keep camber in spec.
Oh and you'll probably want to upgrade the shocks at the same time. Stiffer, shorter, springs will speed up the death of your stock shocks and alot of the handling improvement you get is from uprated shocks, not the springs.
I have H&R Springs, shocks, and DRA spacer/adapters.
