At a loss replaced alternator and its still not charging the battery
A BAD BATTERY CAN THROW OFF ALL OTHER CHARGE TESTS
2. check charge voltage across the battery engine running (rev engine too).
3. check voltage drop alt (+) to battery (+)
wiggle test cable as well
4. check voltage drop (-) battery to ground
wiggle negative cable as well.
Alternator cable failure is rare (so is alternator failure). The battery is usually the culprit in these cars.
