ITALSKIER: Glove box Disassembly Photos
Old Apr 26, 2006 | 03:55 PM
stilljester's Avatar
Member
Default ITALSKIER: Glove box Disassembly Photos
<b> Basic Tools Needed (T25 Torx)</b>
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Glovebox/gb1.JPG">
<b> Your Glove box </b>
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Glovebox/gb2.JPG">
<b>Remove These First - Side 1 </b>
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Glovebox/gb3.JPG">
<b> Side 2 </b>
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Glovebox/gb4.JPG">
<b> Remove the hinge pins next: Get them started with screw driver then use the pliers to pull them out </b>
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Glovebox/gb5.JPG">
<b> After Separating the two halves - Remove the 8 T25 bolts </b>
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Glovebox/gb6.JPG">
<b>Separate the two pieces </b>
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Glovebox/gb7.JPG">
<b>These are the two screws which hold the Quattro emblem on</b>
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Glovebox/gb8.JPG">
<b> Remove them :-) </b>
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Glovebox/gb9.JPG">
<b>If you have any questions buddy let me know. Hope this helps. Also, if you had a small enough T25 bit you could just remove the 8 bolts and the two halfs should also come apart.</b>
Old Apr 26, 2006 | 04:01 PM
Seneb's Avatar
What? No finished product photo?? :-)
Old Apr 26, 2006 | 04:09 PM
ITALSKIER's Avatar
Default thank you so much..........
Im going to just try an go after those 8 t25 's.....I think Ive got a set of short ones and a ratchet.....we'll see,LOL........
Old Apr 26, 2006 | 04:23 PM
Member
:-) I'm sure Sal will post a finished pic
Old Apr 26, 2006 | 06:14 PM
sofTTware's Avatar
Junior Member
Default post hijack....stilljester, can you comment on what i need 2 do 2 install this part?
<center><img src="http://pictureposter.audiworld.com/21765/glove_box_emblem.jpg"></center><p>
TIA! This has been sitting on my desk for 3 months and needs to get installed! I think for starters I need to buy a small Torx screw driver.
P.S. Bought this at VAG Parts in the UK in case anyone wants to get one. I think it was $55 + shipping.<ul><li><a href="http://www.vagparts.com/index.htm">http://www.vagparts.com/index.htm</a</li></ul>
Old Apr 26, 2006 | 06:43 PM
Member
Default Sure - Do you have a small T25 Torx driver? If so remove the 8 screws inside and seperate
the glove box face from the inside. The part you need to remove is held in with two flat head screws. Check out the pictures above and if you have any questions just post away, I'll do my best to answer them :-)
Old Apr 26, 2006 | 07:59 PM
sofTTware's Avatar
Junior Member
Default thx....i need to pick a smaller torx driver up as the one i have is way too long.
This will be my w/e project.
HIS4
Jan 20, 2008 08:10 PM
zaliah898
Nov 19, 2007 03:01 AM
txtony
Jan 30, 2004 06:34 AM
20valvevermont
Jan 13, 2003 12:22 PM
coasTTal
May 1, 2002 04:50 PM
