Help, does anyone know the wiring schematic for the power to the ecu
1) does it crank?
2) have you tested the voltage with a digital VOM?
3) What was it doing when it Quit running?
4) The obvious BIG question is the battery new... most '01's need a battery by now
Is the LCD screen on the dash look normal, or does it flicker, look dim?
You don't know your codes since won't read VAG...
Unknown battery drain?
Let's see what others say.
