Brake flushing question. I'm going to replace my brake fluid tomorrow and had a dumb
Old May 30, 2006 | 10:35 AM
McTTR's Avatar
Default Brake flushing question. I'm going to replace my brake fluid tomorrow and had a dumb
question. Is there any special proceedures (like using the VAG-COM) when I replace the old fluid with the new?
Do I need to activate or open anything with the VAG-COM?
My plan was to siphon out the reservor and fill w/ new. Then pump the peddle to bleed from the back passenger,
back driver,
front outboard passenger,
front inboard passenger and finish up with the front outboard driver and front inboard driver.
I have a Stoptech BBK thus the inboard/outboard sides of the caliper.
Am I missing something or is it this simple? Is there a Fotki or link I should be reviewing?
thanks!
Old May 30, 2006 | 10:44 AM
XCLR8TT's Avatar
Senior Member
No VAG needed. Just bleed as you would anything else.
Old May 30, 2006 | 10:49 AM
GeTT da NeTT's Avatar
Execute your plan.
Old May 30, 2006 | 12:51 PM
msauve's Avatar
Default To do it correctly...
you need a VAG-Com to exercise the ABS system and get everything flushed through it. Don't forget to bleed the clutch cylinder.
Old May 30, 2006 | 01:28 PM
whodkne's Avatar
Member
Default If I remember correctly there was some talk about this a while back and
someone who worked with or for Bosch (I think) posted information that you didn't need to do the VAG procedure and you would never be able to flush out all the fluid in either case. That just using the clutch over time would flush the fluid out... may be completely wrong and I can't find anything easily in the search.
Old May 30, 2006 | 01:52 PM
McTTR's Avatar
Default I didn't see this on my first search. Sounds like people don't do the VAG-com ..
thing. It appears that it causes more problems than it is worth. Here is the Bosch link.<ul><li><a href="https://forums.audiworld.com/tt/msgs/1349668.phtml">https://forums.audiworld.com/tt/msgs/1349668.phtml</a</li></ul>
Old May 30, 2006 | 02:42 PM
whodkne's Avatar
Member
Default Yup, there ya go.. but I think I confused that with the clutch.. so you probably need to bleed that
as well but don't need a VAG either way.
alms_lefko
Dec 23, 2008 08:50 PM
JMS-Four
Apr 13, 2007 12:54 PM
brian a
Misc. Models Discussion
Apr 17, 2001 10:40 AM
Andy Hedin
Motorsport Discussion
Jun 15, 2000 06:41 AM
Andy Hedin
Jun 14, 2000 09:12 AM
