so my car has been "floating" as of late...
Old May 31, 2006 | 06:43 AM
evpho|chop's Avatar
Default so my car has been "floating" as of late...
very very eratic with the steering, it feels almost unstable... i noticed i need new tires , so i am off to buy new tires today and get an alignment... hopefully this solves my problem, but if not, what else are some possible causes for the car feeling so unstable? shocks?
Old May 31, 2006 | 06:49 AM
SquirTTboater's Avatar
Default having same issue...
Shocks/struts.
Hitting bumps makes the car sway and all that good stuff.
Is your car making any bad noises when you hit bumps? If it is, it might be your CV joints.
But I'm going to change shocks/struts and see if that helps my cause.
Local shop (for OEM equipment + alignment) wanted $1000+ for it. Well, hell, for that kind of money, I'll just spend and extra $100 and get Koni's.. that's the route I'm going.
-Scott
Old May 31, 2006 | 07:25 AM
InTTruder's Avatar
AudiWorld Awesome User
Bad wear patterns make it hunt or float badly.
Old May 31, 2006 | 07:34 AM
maaliish's Avatar
Default Hold off that alignment untill you know that you don't have more serious issues.
Would be a shame if you had to replace something and do alignment again.
Old May 31, 2006 | 07:37 AM
Default good call on that.
might have to do the alignment again, and that would be a waste of $$.
divide-and-conquer method.
Old May 31, 2006 | 08:03 AM
evpho|chop's Avatar
serious clunk in the rear when i hit certain bumps... will get that checked.thanks for all the info
Old May 31, 2006 | 08:08 AM
maaliish's Avatar
check sway bar links.
Netopr
Q7 MK 1 Discussion
Dec 3, 2015 08:42 AM
rocketman4321
Apr 30, 2008 04:01 AM
A4tek
Feb 20, 2006 02:28 AM
iwearnosox
May 3, 2005 07:42 PM
shehatezme
Jul 28, 2003 06:00 AM
