help with fuel issues
How we have thought that maybe i was just asking to much from the injectors, so i bought some green tops. Now heres my issue. anything over 15 psi, i hear knock. So i put back in the stock injectors... same thing!
Ive checked my check valves. Ive presure tested my system and everything is fine. Now i havent changed my fuel filter since ive had it, or unless audi does it, i dont know. So thats the next thing im changing, even tho i use 92 and up for fuel.
So any ideas will help tons. I am misfiring in one cylinder, but its like every 7-8 seconds that shows up on vag.
So again, any thoughts?? im very tempted to replace the fuel pump since it use to make noises, a clunk clunk when i was stoped
Pulling back fuel is probably related to what I was describing earlier. Your O2 is doused with raw fuel, and is sending back high voltages to the ECU to call it quits.
Maybe you are just hearing either a boost leak or some other leak, or exhaust rattle. You should hear knock at the engine block and not the exhaust.
