hit HUGE pothole....is it possible to.....
Old Jun 1, 2006 | 04:34 PM
TTmini's Avatar
Junior Member
Default hit HUGE pothole....is it possible to.....
hit HUGE pothole....is it possible to have damage and not know it. alignment is fine. tires and rims look ok as far as i can see. if there was any damage to axle, suspension ect would i be able to tell. that pothole was huge and got my passenger side front and rear tires.
Reason i ask is because i have an 800 mile trip to go on tomorrow.
Old Jun 1, 2006 | 04:38 PM
BluHeaven's Avatar
Default yup....
you can throw your alignment off, bend rims and damage tires without any outwardly visible signs
Old Jun 1, 2006 | 04:40 PM
predaTTor's Avatar
New Member
How fast were you going?
Old Jun 1, 2006 | 04:48 PM
TTmini's Avatar
Junior Member
Default Re: How fast were you going?
hit it at about 25-35 mph. afterward i got it to about 80mph on the freeway with no noise, wheel shake, vibration, or alignment problems. looked for sidewall bubbles inside and out of tire and there is nothing. i just cant belive this car could take a hit like that. thats why i wanted to check here and see if anything could be wrong that would not be noticable.
Old Jun 1, 2006 | 04:54 PM
TTmini's Avatar
Junior Member
Default Reason i ask is because.....
Old Jun 1, 2006 | 06:08 PM
SparTTan's Avatar
Default I would say if you feel nothing strange and car drives straight, you are OK
Watch you tire wear. Check after 500 miles, 1000 miles, etc. for any strange tire wear patterns.
Old Jun 1, 2006 | 06:31 PM
XCLR8TT's Avatar
Senior Member
Default It would be a good idea to have your alignment checked.
Even though it drives straight it is possible you knocked it out enough to give you some unusual tire wear.
Old Jun 1, 2006 | 07:15 PM
predaTTor's Avatar
New Member
Default I am the expert as far as potholes go. >>>>
I've damaged many wheels in my day due to alot of things. But at 35 MPH and if you have atleast 30 PSI, you should be fine. Then again assuming you have like 40 or 45 side walls. But if you ever get the car in the air it couldn't hurt to take a look at the back of your wheels for any damage. Other than that if your alignment isn't even affected .....your fine.
Plus if you've had an alignment recently and the shop warranties it....Just go in and have another one done and might as well rebalance the wheels just for a piece of mind.
 Pouria Savadkouei
 Michael S. Palmer
q5q7
A6 (C7 Platform) Discussion
9
Feb 15, 2014 07:39 AM
Fabio Corsi
S4 (B8 Platform) Discussion
Jun 11, 2013 10:51 AM
fun2fly
Audi allroad
Feb 13, 2004 02:25 PM
SiXGiG
Nov 10, 2003 10:16 AM
Bill In SoCal
Sep 25, 2001 01:18 PM
