Not starting up on the first try
Old Jun 13, 2006 | 09:56 AM
BoxcuTTer's Avatar
Default Not starting up on the first try
It seems whenever I get down to about 1/3 of a tank of gas, my car will just turn over and won't start. If it does, it will stall within a second.
Then the second time I turn the key, it always starts right up. It's been doing this for quite some time, I just never got around to asking about it. Any idea what this could be? Fuel pump? Fuel injectors?
Old Jun 13, 2006 | 10:00 AM
whodkne's Avatar
Member
Default Sure it isn't battery?
Could be the senders or maybe fuel filter.
Do you wait for the senders to prime the fuel system when you first get in the car? You can hear them send a bit of fuel, make sure you wait that second or two before starting.
Old Jun 13, 2006 | 10:11 AM
TTinCT's Avatar
Rest In Peace
Default yep...without the wait with that level of gas in it...it is sure to not be consistent>>
on startup...mine has been that way for years...
Old Jun 13, 2006 | 10:45 AM
MaxHedrm's Avatar
Default Or even with the wait. I can turn it to On in mine, wait several secs, & it still won't start.
It's gotten progressively worse, the point at which it happens continues to get higher. I keep meaning to replace the fuel filter to see if that helps.
Old Jun 13, 2006 | 10:57 AM
BoxcuTTer's Avatar
Interesting. I never knew that. I'll wait a few seconds next time.
Old Jun 13, 2006 | 01:28 PM
BAJITTO's Avatar
yeah, same thing if i crank it right away it wont start, but if i "wait"=>no problems! weird!!
Old Jun 14, 2006 | 06:16 AM
BoxcuTTer's Avatar
Default When does the car send the bit of fuel?
Does it know when I get in the car, or is it when I put the key in the ignition?
Also, what the hell is the point of this "feature"?
magwa
Audi 100 / A6 (C4 Platform)
Jul 24, 2011 08:58 AM
budavid
Oct 10, 2008 03:24 PM
paTTsfan
18
Jun 11, 2008 03:48 PM
Li3ny
Oct 18, 2006 11:11 AM
Tylerb929
Dec 21, 2003 09:46 AM
