How do I get brakes.....
Old Jun 15, 2006 | 11:52 PM
element2050's Avatar
New Member
Default How do I get brakes.....
<center><img src="http://memimage.cardomain.net/member_images/5/web/2285000-2285999/2285155_26_full.jpg"></center><p>I just painted my brakes and I can't get that metal clip back on........ Ne tricks?
and what brakes are the best to prevent dust. I just got Chrome 19s and I'd like to keep them clean.
Old Jun 16, 2006 | 03:47 AM
blackfnTTruck's Avatar
I think I just put one end in and used heavy needle nose plyers to get the other end in.
Old Jun 16, 2006 | 03:54 AM
02TTK04's Avatar
Member
Default Pair of pliers to get the clip back on and almost any aftermarket pad will cut the dust. I have been
thinking of switching to Hawk pads next time. Have gotten great reviews.
Old Jun 16, 2006 | 04:18 AM
adminisTerTurbo's Avatar
Default insert bottom end of the clip first
i have better luck doing that for some reason. and then slide the top one in a little then get channel locks to finish, you'll figure it out
Old Jun 16, 2006 | 05:19 AM
TTagz's Avatar
Senior Member
Default there's a really easy trick to doing it, but it's damn near impossible to explain...
one of those have to see it kinda things. but you get one side barely hooked in so you can put pressure on it without it coming out and you push up on the middle while holding the other end near position and when you get it lined up just release it and it will snap into place. or you can go at it with pliers.
Old Jun 16, 2006 | 06:05 AM
bubba j's Avatar
AudiWorld Expert
Autozone Duralast
Old Jun 16, 2006 | 07:15 AM
TT_Nuge's Avatar
Senior Member
Default What wheels are those?
Chrome? M'kay, as long as you're happy.
Old Jun 16, 2006 | 07:57 AM
BlueChip's Avatar
Default I used a clamp to hold one end in place while I inserted the other end with pliers.
This kept the clamped end from coming out and scratching the paint around it, which it kept doing otherwise and I had to keep repainting it. A real PITA until I tried the clamp and then it went in the first time without ascrathing it.
BlueChip
 Pouria Savadkouei
 Michael S. Palmer
MJ23
Q5/SQ5 MKI (8R) Discussion
14
Jun 26, 2012 10:35 AM
RS4Dave
RS4 (B7 Platform) Discussion
Mar 18, 2009 07:49 AM
SMO
Canadian Discussion
Oct 17, 2008 04:24 AM
yourk
Aug 15, 2005 09:58 PM
info@ecodetuning
55
Jan 26, 2004 08:55 AM
