New suspension and questions...
Old Jun 16, 2006 | 05:05 AM
Kenghh's Avatar
Default New suspension and questions...
<center><img src="http://pictureposter.audiworld.com/92872/img_0027.jpg"></center><p>
Just got the new H&amp;R coilover kit and Forge control arms, and would like to put them on myself. I have read through a couple of the writ-ups and threads here(Thank you! they are very helpful!) but still have some questions and need your help
1. For the adjustable rear springs and front strut, do you always put them on with the highest setting and lower them later?
2. When adjusting hight, does the car need to be jacked up and wheels taken off? (a note that came with the coilover even says for some coilovers the spring needs to be compressed before adjustments?)
3. what about the control arms? do you need to jack up the car to adjust them?
4. usually how long does it take for the springs to settle before I can take the car to the shop for a 4-wheel alignment?
Thank you very much for the help!
Old Jun 16, 2006 | 05:24 AM
Kyle K: TampaS4's Avatar
Default Re: New suspension and questions...
1. Doesn't matter, though higher first is probably easier
2. no, just jacked up.
3. the alignment place would do that on the rack.
4. Ours was aligned right after install. Then realigned a month later. Because the rear control arms are so out of whack.
Old Jun 16, 2006 | 06:10 AM
353/s/'s Avatar
Wait a week before alignment... that will eliminate the double job you speak of.
Old Jun 16, 2006 | 06:49 AM
kodeTT's Avatar
Elder Member
Default putting on at least a couple hundred miles helps (thus, the week duration).
the driving will help to settle the springs to their resting state...from the virgin manufactured state.
the drop will be noticeable...some more than others. not sure about the H&amp;Rs...but undoubtively will settle some.
Old Jun 16, 2006 | 09:51 AM
Kenghh's Avatar
Thank you!
Old Jun 16, 2006 | 09:52 AM
Kenghh's Avatar
Thanks a lot.
Old Jun 16, 2006 | 09:59 AM
Kenghh's Avatar
Default Thanks! So does it make sense...
to put the camber to positive value when doing the alignment a week afterwards so when the springs completely settle the camber won't be too negative? cause I probably won't be able to put a couple hundred miles on within a week.
Old Jun 16, 2006 | 11:27 AM
kodeTT's Avatar
Elder Member
i would dial it in somewhat close and align it later.
 Pouria Savadkouei
 Michael S. Palmer
seinsmeld13
18
Feb 26, 2009 07:12 PM
LexTT225
10
Feb 25, 2007 04:55 AM
marksk1
23
Feb 10, 2007 05:24 AM
scottish TT
Aug 30, 2005 12:56 PM
Er-excess-4
Nov 15, 2001 07:28 PM
