Coilover Question..? >
If you have H&R Coilovers you must also get a rear camber kit, control arms, and defcon then an alignment...
Is this all necessary?
And is this limited only to H&R coilovers, or will I also need all of this with KWv3 Coilovers?
Just weighing out my options. thanks
You will definitely need an alignment, though, so if you plan on doing the Defcons, you may as well do them now so you don't have to spend on the alignment twice.
*You will need some sort of KMAC setup or different arms to get your rear alignment back into spec if you have a quattro. Unless, of course, you keep the car at stock ride height -- but why would you want to do that? ;-)
Alignment is a MUST do after install.
DEFCONS and RSB is just "complimentary"..
I was looking to go 1.5-2 in the front and a little lower in the rear to level it out... Which i hear can be done by removing the rear perches on the H&R coilovers..
That low you will have to experiment with wheel offsets, spacers, and tire shapes (different brands and styles have different profiles)to keep from rubbing.
Correct on DEFCON and RSB.
Thats why I ask alot of questions to ensure that I will be doing everything correctly..
I think ill stick to:
H&R Coils
full KMAC
and Alignment for sure
Reading the modshack site, the Defcon 1 seems like a must, and also a RSB... 19 or 21mm? Which is recommended..
