calibrating mpg indicator after 4 bar, need help. it won't accept new values
Old Jul 5, 2006 | 04:08 PM
adminisTerTurbo's Avatar
Default calibrating mpg indicator after 4 bar, need help. it won't accept new values
i went through the steps on steve's site and it wouldn't change to 105. i used intervals of 5. isn't there someway to do it through the recode function. i've done it before successfully. now...nothing.
Old Jul 5, 2006 | 04:24 PM
RoberTT-WWCD's Avatar
Default Try this...>>
To correct using a VAG-COM:
- From the main screen, under Select Control Module click 'Select'
- Click '17-Instruments'
- Under Advanced Functions, Click 'Adaptation - 10'
- Type 03 in the channel number field and click 'Read'. In the stored value, it should read '100'
- Use increments of 5 until you get it dialed. Also, pad the value with zeros. Example - in the new value field, type '00110' and press Enter.
- 110 should appear in the Test Value field
- Click 'Save'. Click Ok to complete and click Done to exit.
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Are you using a registered version of VAG COM? ....>
Probably not an authorized function with the shareware version..
Old Jul 5, 2006 | 04:27 PM
yes, it's the real deal from ross tech
Old Jul 5, 2006 | 04:28 PM
i'll try that with the zero's, wasn't doing that before.
Old Jul 5, 2006 | 06:22 PM
got it with the zero's
TreeSkier
Q5/SQ5 MKII Discussion
May 2, 2018 11:36 PM
RoberTT-WWCD
20
May 4, 2005 03:57 PM
Fairfax 4.0T
VAG-COM Discussion
Apr 23, 2005 08:21 AM
wnut
Dec 12, 2001 05:55 PM
audi2001a4
Aug 30, 2001 03:26 PM
