calibrating mpg indicator after 4 bar, need help. it won't accept new values
i went through the steps on steve's site and it wouldn't change to 105. i used intervals of 5. isn't there someway to do it through the recode function. i've done it before successfully. now...nothing.
Try this...>>
To correct using a VAG-COM:
- From the main screen, under Select Control Module click 'Select'
- Click '17-Instruments'
- Under Advanced Functions, Click 'Adaptation - 10'
- Type 03 in the channel number field and click 'Read'. In the stored value, it should read '100'
- Use increments of 5 until you get it dialed. Also, pad the value with zeros. Example - in the new value field, type '00110' and press Enter.
- 110 should appear in the Test Value field
- Click 'Save'. Click Ok to complete and click Done to exit.
RoberTT-WWCD
20
05-04-2005 03:57 PM
audi2001a4
08-30-2001 03:26 PM
