heres a dumb question, how to clean the K+N in the TTDA?
Old Jul 6, 2006 | 03:57 PM
silverTTQC's Avatar
Default heres a dumb question, how to clean the K+N in the TTDA?
Its been a long time since I've been to the boards as well as being able to work on the car. I figured its due time to clean the K+N filter in the TTDA, however, how in the world do you clean it? I thought it was able to be removed from the housing, am I wrong?
Old Jul 6, 2006 | 04:07 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Easy...
To remove filter, take the box out of the car, remove the vinyl edging from the filter side and the whole endcap with filter attached can be removed. If the end cap is too snug to remove easily, simply insert a long screwdriver into the opposite end (inlet holes) and tap lightly around the circumference of the filter base. Follow the K&amp;N procedures for cleaning, Lightly oil, and re-assemble. K&amp;N cleaning kits can be sourced at most any auto parts store that sells filters<ul><li><a href="http://www.knpowersports.com/clningins.htm">Official K%N cleaning procedure here..</a></li></ul>
Old Jul 6, 2006 | 04:50 PM
Death sTTar's Avatar
What, it needs cleaning!!!
Old Jul 6, 2006 | 04:53 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Only if your motor runs.....:-)
Old Jul 6, 2006 | 05:51 PM
Ooooo, touche!
Old Jul 7, 2006 | 02:29 AM
CrazyTT's Avatar
LOL... When I had the TTDA with hoses I found a few Oak leaves stuck in mine...
Prime Time
A4 (B8 Platform) Discussion
17
Mar 16, 2015 01:56 PM
abarmard
Oct 31, 2012 11:27 PM
G8TTR
Dec 19, 2003 11:46 AM
V8_SPANKER
Aug 10, 2003 06:49 PM
Pelican18TQA4
May 19, 2001 09:06 AM
