225 hp engine dv
Old Nov 17, 2006 | 11:43 AM
s3225hp's Avatar
New Member
Default 225 hp engine dv
please can anyone tell me which is the best dv to install in my car!
please i am in a mess!!!
Old Nov 17, 2006 | 11:47 AM
AxeYrCat's Avatar
Member
Default Lots of options out there, really. Depends on how much you want to spend and how often...
You want to service your DV.
SuperBob916's Avatar
New Member
Default up to preference it seems....
alot of us use the forge 007, others use the bailey, hyperboost, do a search and look for opinions
Old Nov 17, 2006 | 12:01 PM
s3225hp's Avatar
New Member
the money is not a problem if the dv really works!
Old Nov 17, 2006 | 12:07 PM
RoberTT-WWCD's Avatar
Hijaak... Chris, what's the status of your car???
Old Nov 17, 2006 | 12:26 PM
JustJeff's Avatar
Hyperboost HX
Old Nov 17, 2006 | 12:46 PM
JohnLZ7W's Avatar
They all work, keep it simple, hyperboost or Forge 007.
Old Nov 17, 2006 | 12:59 PM
AxeYrCat's Avatar
Member
Unchanged, it seems. Still at APR. Still waiting for parts to come in, as I understand it.
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 17, 2006 | 02:06 PM
RedRoadster's Avatar
Member
Default If yours ain't broke...
then I suggest you leave it as is! If it really is failing, I can't think of any reason to mess around with anything that is adjustable or needs re-lubing more than once in a very long while. Trust me, I messed around with several of these (although my oem dv was failing the day I got the car home) and you'd be hard-pressed to notice much of a difference between them. Good, oem-type fit so you don't twist the vacuum line is key; i'd recommend the hyperboost hx compact.
Old Nov 18, 2006 | 04:37 AM
02TTK04's Avatar
Member
Have tried 4 different ones now and always come back to the 007P.
mzielinski4
17
Apr 11, 2006 05:59 PM
bronco
Mar 29, 2006 12:00 PM
TTommyB
14
Dec 11, 2002 06:46 AM
KevTse
Jul 30, 2002 06:04 AM
seaTTym
Aug 17, 2001 09:35 AM
