Installing Koni fronts and they have the adjustment tab where the hazet tool goes in the center
Old Nov 18, 2006 | 04:26 PM
whodkne's Avatar
Member
Default Installing Koni fronts and they have the adjustment tab where the hazet tool goes in the center
of the piston. How the hell do you tighten then down if you can't use the hazet tool?
Old Nov 18, 2006 | 04:33 PM
XCLR8TT's Avatar
Senior Member
Impact wrench
Old Nov 18, 2006 | 04:37 PM
nikhil's Avatar
Default O2 sensor socket, 1/4" drive extension down the center, crow's foot on O2 socket
check the PureMS site for more details
Old Nov 18, 2006 | 05:03 PM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
I'll try to remember to bring my O2 socket tomorrow.
Old Nov 18, 2006 | 05:15 PM
whodkne's Avatar
Member
TRY!? TRY!?! BRING IT PLEASE!
Old Nov 18, 2006 | 05:16 PM
whodkne's Avatar
Member
TY
Old Nov 18, 2006 | 05:22 PM
HACK THS's Avatar
Default You need a 11/16th spark plug socket for the nut, but around the adjustment tab
you will see it accepts a 11mm socket. I did the typical deal with the 11mm socket inside the spark plug socket with an extension and a 1/4 socket, and positioned it to put pressure on the hood hinge. That will hold the strut in place and not spin. I then too an open ended wrench and tightened down the 11/16 spark plug socket on the nut. Worked perfectly... Do a search there is a post about it from Mike @ Pure Motorsports.
Old Nov 18, 2006 | 05:46 PM
Tech Guru
Default Actually, you should be able to run a 1/4" drive through the center of the outer Hazet to the same
or better effect. Can you try that tonight?
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 18, 2006 | 06:38 PM
ArTT Vandelay's Avatar
ding
Old Nov 18, 2006 | 06:42 PM
XCLR8TT's Avatar
Senior Member
More power.. Arrr..Arrr
