Installing Koni fronts and they have the adjustment tab where the hazet tool goes in the center
of the piston. How the hell do you tighten then down if you can't use the hazet tool?
You need a 11/16th spark plug socket for the nut, but around the adjustment tab
you will see it accepts a 11mm socket. I did the typical deal with the 11mm socket inside the spark plug socket with an extension and a 1/4 socket, and positioned it to put pressure on the hood hinge. That will hold the strut in place and not spin. I then too an open ended wrench and tightened down the 11/16 spark plug socket on the nut. Worked perfectly... Do a search there is a post about it from Mike @ Pure Motorsports.
