Exhaust smell in the cabin, Boost not holding correctly.
Wed. Morning on my way to work I was stopped at a stop light and noticed the smell of exhaust in the cabin...to the point that I had to roll down the window.
Today the car will peak at 15psi but then drop to under 7psi (225, boost machine, stock ecu,) at anything over 4500 rpm. I turned off (down,) the BM when I got home; see what happens on the way to work tomorrow.
I'm suspecting that the exhaust leak is the joint between the down pipe and the Cats, but I just wanted to run it by everyone to see if there is a known failure point or anything.
Running rich will smell like gas and cause the ECU to shut down at higher RPM's. I'd pull and check the plugs first. Good luck.
