Shock bolt question: Is it ok to substitute the bolt>>
Old May 15, 2007 | 01:00 PM
TwisTTer's Avatar
Default Shock bolt question: Is it ok to substitute the bolt>>
the longer bolt (left)for the one the right (stock)?
For some reason installing V3 shocks on the rear caused the bolt(pictured on the right) to come up way short.The bushings were a lot thicker on the KW shock than stock shock causing the bolt to not make it halfway through the control arm.
I called the dealership and found a longer one that is used for the A4 same metric size (10.9N) but slightly longer. The only possible issue is that the bolt is threaded all the way to the top. The parts guys at the dealership say it's no problem but I trust you all on the forum more so I just wanted to confirm it before I drive around with the car.
Here it is:
<IMG SRC="http://img.photobucket.com/albums/v685/twistter/fmicbolt.jpg">
Old May 15, 2007 | 01:07 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Should not be an issue...>>
Just curious why no one else has reported this..
Old May 15, 2007 | 01:11 PM
TwisTTer's Avatar
Default me too...I did not have that issue when I installed V2's shocks at all, although the shock design is
a little different.
I should have taken a pic of the stock shock and KW V3's.
I can tell you that there was an additional thickness 2-3mm on each side of a single shock.
That is a drastic difference and would definitely prevent stock bolt from working at all.
Thanks for clarifying that Steve!
I'm off to do my test drives.
Old May 15, 2007 | 01:20 PM
TwisTTer's Avatar
Default after I was done tightening it to spec this is roughly what left of the thread...
<IMG SRC="http://img.photobucket.com/albums/v685/twistter/longerbolt.jpg">
Old May 15, 2007 | 01:31 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
That'll be fine!
Shefoz
A4 (B8 Platform) Discussion
Apr 10, 2019 07:35 AM
myers1.8TQ
Oct 10, 2008 03:14 AM
TToplessTTs
Feb 2, 2007 05:24 PM
JJMcWank
Jan 27, 2006 03:09 PM
1.8Steve
May 17, 2002 08:25 AM
