Oil Change & Leak
Old May 20, 2007 | 05:50 AM
leveTT's Avatar
Member
Default Oil Change & Leak
Just changed my oil and noticed a small leak. I think it's coming from the drain plug. The drain plug seemed to bind somewhat upon removal. Any ideas?
BTW, I used Castrol Syntek 5W40; they say it meets BMW, Mercedes & VW specs. Also used a Fram filter; $4 vs $13 for an Audi filter.
Old May 20, 2007 | 06:07 AM
TTinCT's Avatar
Rest In Peace
Default make sure you use the crush washer too>>>
without that, the drain plug will leak almost every time...
Old May 20, 2007 | 06:33 AM
Cruzad3r's Avatar
Default you want to check the thread of the drain hole, not the drain plug..and if you see any wear/tear you
want to rethread immediately... helicoil kit 14x1.5 cost around 80-100 buks... or you could swap out the pan like me ... look for my pix for reference. I'll post them soon enough..
good luk
Scenic Driver's Avatar
... and a new crush washer everytime
Old May 20, 2007 | 05:11 PM
leveTT's Avatar
Member
Default Re: you want to check the thread
Help. How do I check your photos?
beejohn
Mar 16, 2008 04:49 AM
stilljester
Nov 7, 2005 10:19 AM
Digger Killer
10
Jul 26, 2004 10:33 AM
brooks
Jan 6, 2003 03:17 PM
LouisE
Dec 19, 2002 10:08 AM
